Turbo_T
About Turbo_T
    Female
    essex
  1. where u get your spacer plate from and head bolts ?
  2. well few updates spoke to jim last week and will be meeting him soon to take a look at the car and hopefully get some new mapping and need to get a head spacer fitted been doing few bits to the car fitted 2 new rear calipers as they was sticking on also changed the thermostat housing as this had a crack in it fitted 2 new lambdas but might have to have play with theses as seems i only have 3 fitted lol fitted 1 new tyre today as the tennis ball growing out the sidewall was starting to get Bigger also removed carbon canister and ordered a washer bottle as mine been removed for the turbo pipe
  3. like the pump right up i got to do one on my v6 bought a spare pump unit with sender for £30 will get the walbro at end of week fit it all and then change it over
  4. im looking to fit a walbo but sure i see somewhere for the mk4 at least u need a certain fitting kit or it wont fit dunno if its same for yours mate
  5. hi mate just been reading this as i just bought a 4mption thats been turbo'd but needs setting up and some more mods doing
  6. yeah i had 3 codes for the secondary air system but 2 ive sorted with resistors the angle sensor im going to try recalibrate one day and see if that fixes it
  7. gone quiet on here lol well bit more update info when i got the car home i plugged vagcom in and found 32 fault codes lol i cleared them all and rerun the car and 11 came back i since been working on sorting them and got it down to 5 now , 2 which are lambdas which ive ordered 1 a abs sensor which i have now 1 is steering angle fault and other is secondary air pump reply ( which is missing lol ) so by middle of next week i should only have the 2 last codes left then ill strip it down and check injectors and hopfully get a remap booked
  8. thats what im thinking if i can get a chance and its not that hard to do i will try get to the injectors and see what thay are
  9. well it was converted a few years ago i think and has had a hard life lol im not 100% on everything but its running a GT30 turbo has uprated injectors (not sure which) Apexi SAFC2 external wastegate with a screamer pipe i think and uprated clutch Its has a second hand engine fitted recently (not 100% why) but this is a standard engine so im looking to sort a head spacer as sure its not good running without it its running the standard map still so looking to get it remapped and its been setup using the SAFC2 but think someone has messed that all up as its not quick and dont like boosting in th
  10. Hi all i have a 4motion turbo and looking to see if there any others on here for some help and advice Ton y
