andymk312v
Days Won
1
andymk312v last won the day on January 7 2014
andymk312v had the most liked content!
About andymk312v
jez_monkey reacted to a post in a topic: genuine accelerator pedal cover?
Skateboard griptape #cosracecar
Standard airbox flows best, put in a dry element replacement filter. Oiled filters like k&n and pipercross ruin vag mafs over time. Bmc cda's have been proven to restrict a 20vt wouldn't imagine the vr will suck less air. Cba searching but there is a good comparison thread on vortex a guy with a vrt has done the standard airbox was best for the engine.
VR6Pete reacted to a post in a topic: What is this for?
I made one for my leon out a metal water bottle, worked mint. Vr bay is a bit tighter though. Only problem I see with running just a pipe is oil hitting the road.
I run a long pipe to the back of my subframe. Want to install a decent catch can system though.
As above poly all the way just for ease of fitting.
Hubcentric adapters on rear of mk3
andymk312v replied to jamesw6810's topic in Wheels, Brakes, Suspension and Steering
Yeah but it will make the lip the wheel sits on very thin. Better to modify the disc. -
I run 20mm hubcentric's with a 5mm universal behind them. Make sure they are torqued correctly and its fine. Easily done 5k like that. -
BBS RXII RS771 6.5jx16 Tyres?
andymk312v replied to OurVR6's topic in Wheels, Brakes, Suspension and Steering
That's a big balloon of a tyre, as above probably won't fit the best. -
I'm running 195/40's but its personal preference really. How low is the car going to be? -
andymk312v reacted to a post in a topic: Mk1 Vr6 update
I think that means your maf has had it. The car should change when its unplugged, (if unplugging when running) it will change to a safe level of Fuelling as it has no idea what's going on without the maf.
What you building to have the radiator in the back? Sounds interesting..
Oil Pump push rod snapped
andymk312v replied to sharma187's topic in Engine Maintenance and Problems
As united says, engine will be fucked. -
Low oil pressure could cause the chains to come slack and jump a tooth. Have you checked the timing marks? -
Issues with what? Heat is good.
