Days Won
1
shawy last won the day on October 17 2013
shawy had the most liked content!
About shawy
- Birthday 12/25/1976
Gender
mancheser
Interests
fast cars mufc
shawy started following Swivelonit
Swivelonit started following shawy
Got a mint 24v engine here £500
Tyre opinions and experiences
shawy replied to VIW28's topic in Wheels, Brakes, Suspension and Steering
R888 is a very good road tyre better than anything I've used ..yokos are the worst wet tyre I have ever used good in the dry. 17" r888 can be picked up cheap part worn with one trackdays use .. -
3 Ohms resistor from memory . Don't know what model u have but my vagcom can turn off belts and s/wheel if aftermarkey parts r fitted.
Proper ecus will cut serious time off the turbo cars
Soft suspension ditch rear roll bar launch control for a good 60ft time ..
can someone help on this steering rack number r32
shawy replied to shawy's topic in Wheels, Brakes, Suspension and Steering
Thanks will have a nosey -
Normally the abs ecu is incorparated in the pump. U can tell by the plug on the pump .. how many wires.. Not clued on mk3 golfs but its very rare its seperate..
Look up andy forrest .. bigger engine capacity is always faster .. less horsepowerper cylinder .. if 4 cylinders is quicker its only because the 6 cylinder guys have not pushed them yet ..
Oh yes fancy a dabble. I'm in..
Sounds like pump is faulty .. or no power to the abs pump.. If its disconnected I would go with the pump being goosed. Mk 3 or 4
As above don't mind spending a bit of money upgrading if there's stuff u can do but dont wanna be spending 4k on a gear set .. Plans are to fit a lsd uprated . Heard about replacing rivets in selectors? New bearings Is there some type of box strenthener to keep the box together .. Anything else .. Thanks
It was on a 2.3 subaru engine running 28 psi made 690 bhp made full boost at 4400 rpm .. Was thinking of fitting a t04z to my vr6 but they don't seem to spool very well for cylinder engine size .. And with them not revving so high they need to spool fast... But I've not seen any proper builds with decent fuel and a proper engine management system so that may help a lot also only seen 12v heads no graphs for 24v builds ...
Opinions On Poly Topmounts?
shawy replied to rbertnitro's topic in Wheels, Brakes, Suspension and Steering
I hate powerflex stuff seriously garbage .. not used anything on golf yet but I used superpro and whiteline..
