Allymk2
  • Days Won
    1
Allymk2 last won the day on March 20 2014
Allymk2 had the most liked content!
About Allymk2
  • Birthday 02/04/1973
    Aberdeenshire
935 profile views
  1. Sounds like a job for the "TOAF" crew lol!!!
  2. cheers, just a bit frustrating at the cost but that explanation kind of helps, I work in the oil and gas sector in Aberdeen so should have known better, is TTS the only supplier in the UK? Sent from my T100TA using Tapatalk
  3. Yeah I've got an empty bottle of rotrex oil but the crafty bastards dont put the spec's on it like youd find on any other bottle of oil, just found out you can buy a litre of it from america for $99 WTF!!!!!!!!!!!!!!!!!!! robbing bastards
  4. I'm looking for some advice as to which injectors to use with my rotrex charger. Also which oil as the rotrex oil is bloody expensive.
  5. Is it the slim line fans your using if so you'll have to solder some diodes in, there is a web page that gives you instructions, I'll try and find a link
  6. No worries I'll send some photos and possible help with the build, doesnt look to difficult just time consuming.
  7. I'm sure it would as the mk2 and mk3 are pretty similar underneath. I've got quite a few photos of the build to help me with mine.
  8. Yeah It's a bloody good setup, takes a bit of time and fabrication.
  9. Hows about this then. Its someone I knows mk2 running a complete mk5 r32 rear end and O2M gear box with separate haldex controller. This is the setup I've got in my garage ready to attach to my edition 1 mk2 golf.
  10. Allymk2
    meth
    The black piping is supplied with the kit, think there is 4 meters. Sent from my HTC One using Tapatalk
  11. Allymk2
    meth
  12. Allymk2
    meth
    Sorry I've not sent the info will do it tonight, here is a photo of where I mounted the pump. Sent from my HTC One using Tapatalk
  13. Allymk2
    meth
    Hi Lee it was the stage 1 6-30 psi kit, i'll scan it in and send a pm to you
  14. Allymk2
    meth
    Lee, I just fitted a devilsown system to my mk2 vr6 with a Vortech charger and it was pretty straight forward. Can give you a copy of the fitting instructions so you can see for yourself. Biggest problem I found was where to fit the pump. Sent from my HTC One using Tapatalk
  15. Alright gents, considering putting an oil catch can on the mk2 but dont want to buy some shite from fleabay, any advice on this i.e make/supplier. Cheers!!!!!!!!!!!!!!!!
