Days Won
1
Everything posted by Airone
Engine mount... For the centre of gravity if nowt else....
I have a very low mileage 4motion box if that's any good?
Bora 2.8 4Motion transmision very low miles 40 odd perfect condition
Airone replied to Airone's topic in General Items
back up still available... -
Bump nobody need any very low mileage 4motion parts?? -
Loving the work area...!
Must admit I do like the idea of these hybrids the wife is looking at the A3 etron which is pretty much the same car, Clocks arn't digi but cool all the same, loads going on under the bonnet, Power unit in bits Under the skin, Will never sound like a VR but I suppose that's progress I just keep telling myself that it could be worse I could be two generations younger and be even closer to relectrickery domination........
Nice Daveyboy and Aired out too by the looks????
Looking good man
come on Ahmed progress pics please???
cold wet happy.
This may be of interest?? http://www.clubpolo.co.uk/forum/index.php?showtopic=256072&hl=
The KR is the predecessor to the ABF and is 1.8...hence my Q I have both a KR and ABF sat under my bench and just wondered as they both look the same....
Is the ABF and the KR the same block only stroked to achieve the extra 200cc???
What you probably need is the shell as well...........or at least the rear floor.
WELL!!!!! Put a "used" Bosch air flow meter on a shit a brick what a difference it pulls all the way to the red line and doesn't lett! gets to about 4. 4 1/2 and its like hitting the power band on my old KX250 crosser...... What a machine I can't believe the difference mind especially after spunking 90 quid on a brand new pattern part last year... Just hooked up the trailer and dragged a transit pickup up the yard to weigh in and it was like towing a little up! or mini ( BL Mini that is ) or summat the thing just pulls and pulls........ Very happy bunny!! it can do 10 mpg for me
Right sorted a full scan and this is what came up, I already fitted a new airflow meter but apparently it has to be a proppa Bosch part so I'm gona try a bosch airflow meter and the oxygen sensor, Any idea which is bank 2 sensor one and were is the camshaft sensor? Cheers fella's........
Cheers Swivleonit, I've never even herd of a lateral sensor so I need a proppa scan with proppa VCDS thanks again just need to find someone local with full setup.
Well I have been running this for a while now and find this power restriction is getting worse all the noise with no lift my 110 afn tdi is quicker, I have addressed all of the results above and am starting to wonder if the cat or rear silencer is causing a restriction in the exhaust resulting in a huge loss of power. Anyone had this problem???????
I think it looks mint man lovin the 3" intake looks the part for sure.
car not idling when pushing in clutch
Airone replied to mrslippery22's topic in Engine Maintenance and Problems
I bet its a vacuum leak. -
called the locksmith
