Goudgey
About Goudgey
583 profile views
  1. Hi mate ,from stealth racing,a few years back
  2. Hi all, I'm after some advice please,after a few years running a supercharger on my vr6 which I love to bits,I've decided to build another motor and turbo it,there is a couple of kits I came across,one was from X-PARTS.de ,or CARLICIOUS-PARTS.COM using a Garrett gt3076r,thanks for your time any help would be great
  3. Thanks very much for your help,ordered a vw sensor now just to cover myself,will sort out a wideband afr unit aswell,thanks for your time.
  4. Hi haven't tried,only stationary with the engine temp hot,don't know if I should try another sensor but a Oem one,thanks for your reply
  5. Hi got a problem with my 1997 supercharged vr I can't get a lamba reading using Vagcom what so ever,so changed the sensor for a new one it's a NGK one,still no readings,checked all the wiring,I am getting a faulty ecu code all the time but the car runs ok but holds back a little until high rpms so I thought it was down to the chip install that went with the supercharger,do you think the ecu isn't registering the sensor. Thanks for your time any help on why I can't get a readings would be great
