Days Won
1
Liam Potts last won the day on April 16 2014
Liam Potts had the most liked content!
About Liam Potts
Contact Methods
Website URL
https://www.facebook.com/liam.potts.12
Gender
Manchester, United Kingdom
Ickyketseddie reacted to a post in a topic: mod hatred!
daveyboy reacted to a post in a topic: mod hatred!
damian8588 reacted to a post in a topic: mod hatred!
Liam Potts reacted to a post in a topic: mod hatred!
Cars that arnt driven! I don't have a particular hate for anything as each for there own... But trailering your car to a field to polish it doesn't make sense. Style it how you like do whatever your mind allows but for gods sake drive it and every now and again do it properly! rant over Sent from my iPhone using Tapatalk
I'm running Ap's on my mk2 vr can't fault them for the cost and comfort levels are lush in comparison to the eBay specials If I was being picky then under hard driving they feel a little soggy could do with a little more bound/re bound rating, but you get what you pay for. Sent from my iPhone using Tapatalk
Have you got 12v to white and black trace when you switch lights on with ign on?? Sent from my iPhone using Tapatalk
Liam Potts reacted to a post in a topic: Spark plugs. Any cheaper alternatives? HT leads recommendations also!
Vr6 engine loom wire identification needed
Liam Potts replied to Shiver's topic in Engine Maintenance and Problems
Thin black and yellow is normally aux water pump feed Sent from my iPhone using Tapatalk -
As above ^ The red with black trace is starter exciter wire Have you the PIN numbers or plugs on the fusebox end? Be able to trace everything very easily for you if so bud Sent from my iPhone using Tapatalk -
Change the lot ) Chains stretch over time(depending on servicing and oil quality that time can be less or more) this leads to tensioners being at the limit of there travel and/or the tensioners age and don't hold suffice oil pressure to keep the chain under tension. Both will lead to the chain slapping about and damaging the guides. Not normally the guides themselves that started the noise Sent from my iPhone using Tapatalk
What were the reasons for being advised away from poly? Just curious I'm running them and have fitted and driven a few on the vag platforms Removal~ I burn the rubber out then cut a small incision into the outer sleeve and fold it in on itself, just falls out of the axle then. Installation~ ensure the axle is cleaned up prior. poly are nice and easy to fit just slot in by hand with a bit of rubber grease. OE spec stuff you'll be needing to borrow the installation tool to press it in without damaging it, they're an oddball shape to be making things for Sent from my iPhone using Tapatalk
VR6Pete reacted to a post in a topic: Headlight issue
From memory the systems use the headlamp flasher/main stalk as relay pull plug off stalk switch lamps on and bridge the white with black trace to yellow(dipped beams should come on) then bridge same to white mains should illuminate if so then your stalk is faulty Sent from my iPhone using Tapatalk
