tubbs76
About tubbs76
494 profile views
  1. Yeah, ive run bosch super plus Yttrium. part # FLR 8 LDCU+ never had a problem with em and they are a fraction of the cost
  2. me starting to thinks so too. Picking up two regs and motors complete tomoz and just swapping both out. I know it will def fix the drivers side as the reg brokw however my gut feeling tells me the passenger side is still a power issue for some reason.. See how we go when i replace them both tomoz
  3. i unscrewed where the wires are all coming out of the cavity to give me a litle more room to work with and have a look. everything seemed fine. Took me a few attempts o lock it back in however after doing so, im not even getting a click from the switch or the wiper any more , completely dead. Hopefully just a coincidence otherwise ive fucked it up even more trying to see if wiring was the issue.can be a relay or a fuse otherwise non of the windows would work. rears are still fine and I can still control electric side mirrors thorough drivers side door switch for both sides.
  4. Cheers for this guys, i had a look at the looms in both doors and cant seem to find any issues in terms of split wires or wires that may be loose. Ill look again tonight but pretty sure that they are all ok. Might be easier just to pull both out and replace regs and motor complete. 1 small problem, the front passange side is up with no wat of getting it down, Im assuming ill have to cut the reg in order to slide it down so I can undo the 2 screws holding the glass in place. Front drivers has been removed already and had 2 pieces of timber keeping it up. Appreciate the offers for part guys. id
  5. Hi all, Having a few issues with the dreaded Mk3 electric windows. I'm hopping that someone can help shed some light on this issue. My front drivers side window stopped working about 2 months ago and last Saturday, my drivers side front stopped. From what i can tell, the regs look ok, and im pretty sure that the motors are getting power to them as when you hit the switch to wind the window down, you can hear the clicking noise from the switch itself and also from the motor. When hitting the switch, the interior light also dims on / off which I would imagine tells me that there is power getti
  6. exactly, i dont mind it under full throttle, its the drone that kills me.. might put i hotdog in just to take that drone away.was loooking at this http://www.ebay.com.au/itm/251379420821?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
  7. Hi all, I am currently running a complete Remus exhaust from headers back on my obd1 94 VR6 which also consists of Remus suitcase and rear muffler. In my opinion, wasnt loud enough so I deleted the suitcase and just welded in a pipe in its place. Ofcourse with the Remus back box, it is bloody loud, a lot louder than i anticipated. Any advice on making it a little quieter? More the Drone that annoys me. I was thinking something along these lines but dont know how much of a difference it will make if any at all. http://www.ebay.com/itm/390748812742?ssPageName=STRK:MEWAX:IT&_trksid=p3984.
