RemsVR6
Everything posted by RemsVR6
  1. A little update of my topic : this week end, i bougth this : The Kamei Gril are not delivery, a seller have make a mistake to the delivery conditions and i can't receive this part...
  2. I thought to the ignition barrel, because, if i move a little bit, the power turn off... i will replace these 2 parts, and see the results. it is possible to change the diagnostic connection to connect it directly to the ECU ?
  3. When the engine is started, i don't have problems, it's just a start cycle the problem. I have to stay five seconds on the starter to start the engine
  4. Hello, after a long period i'm back, i see today your answer If i connect the battery for the first time, the engine run immediately, but after the first start, when i want to start again, I have to operate the starter for 3 to 5 seconds before the engine starts i bougth a scanner U281, and after analysis, "no error" or "linking error", i tried to use VAG-COM but i can't to read in the ECU... i tested the ignition during the starter activation, and it's ok... i maked a topic for this in the "Engine Maintenance & Problems", i expected the answers now The good news now
  5. Hello, i have a problem with my mk3 and this since the day of acquisition... (Engine type AAA / 1992) If i connect the battery for the first time, the engine run immediately, but after the first start, when i want to start again, I have to operate the starter for 3 to 5 seconds before the engine starts i bougth a scanner U281, and after analysis, "no error" or "linking error", i tried to use VAG-COM but i can't to read in the ECU... i tested the ignition during the starter activation, and it's ok... Can you help me ? Thanks
  6. Before my restauration of Head gasket, i have this problems : - ABS light turn on - Scan my ECU with Scanner U281 it's impossible - I don't found a tuto for install and use VAG-COm on MK3... Can you help me ?
  7. Thanks for this infos i visit a lot of topics, it's very interessants :-) My topic : http://www.vr6oc.com/forum/topic/45482-my-french-mkiii-vr6/
  8. Hi all ! After my personnal presentation, it's time you present my car :-) It's a VR6 OBD 1 to 1992 Paint is recent Adjustable suspensions TA TECHNIX Interior GTI EDITION I have a lot of bad surpirse on this car, bad former owner... So, i repair this car step by step but it's too long Mechanical problems, electric problems... My VR6 durind a BMW ride on Provence in the South of France (OEM Double optique black) Actually i repair my head gasket : valve stem seal / hydrauliques tappets See You !
  9. I'm a New Normand i live in Normandy since to 1 week and i love this Region Landscape / Hystory / Mentality of People here I go to create a new topic for my car
  10. Thanks :-) I live in Normandy
  11. Hello EveryBody, I'm Remy, 26years, a French guy i have a MK3 VR6 of 1992, it's a OBD 1 I'm on this Forum because the French Forum for VR6 is very light to resolve technical problems (Sorry for my bad language...) See You
