Days Won
10
fleety last won the day on September 28 2021
fleety had the most liked content!
About fleety
Gender
Northern Ireland
Interests
VAG
Got the correct engine carrier for corrado vr6 2nd hand bought in from Germany and fitted to car on Thursday just in time for MOT last night and happy to say the car passed without any issues [emoji3060]
Yes at some point the crossmember was changed out for one out of say a g60 corrado and the top half of the rubber mount was cut off in order to lower the engine to allow clearance between engine and bonnet, so when i put in another mount it has pushed the engine up high. So rather than cut the mount just to make do i am searching for the correct crossmember because if i cut the mount down it will probably rip apart in no time.
fleety started following ABS problems , Wanted , Vw corrado vr6 engine clearance and 2 others
Has anyone got a front crossmember for sale to suit a vw corrado vr6.
So the front engine mount failed and the engine twisted and damaged the bonnet so i had all 3 engine mounts replaced and bonnet repaired and painted but when driving the car today i can hear the engine is still thumping the bonnet when i change gear, is there any other parts that may be faulty in order for the engine to move so far.
Knopfi reacted to a post in a topic: POST A SINGLE PIC OF YOUR CAR
Waringstown.
Waringstown.
fleety reacted to a post in a topic: POST A SINGLE PIC OF YOUR CAR
OK so my vw corrado vr6 started to creep up on the temperature gauge so I ordered a new thermostat, water pump and fan sensor. I got the Lot NEW for £45 and booked the car in and firstly my mechanic changed the thermostat and "He" put an engine flush in and told me to drive over the weekend so today he replaced the water pump and fitted the fan sensor to the radiator and topped the system up with coolant mix again at his expense, so I have taken the car for a good drive and have left running and i just can't get the car close to overheating. Brilliant work and results until I got the bill £50
I've no way of of testing but the resistor is looking in rough shape would this effect the pump operating plus mine isn't fixed to the front of the pump it's up under the expansion tank held with a cable tie. And had some moisture around the connection.
Also Bba-reman were on the ball and advised me that after I reinstall the pump they checked over for me to then run a diagnostic test and phone them with the codes and they would try to resolve for me.
The last time I tried to clear errors myself it came up as failed but as I recall they have returned, this is in a vw corrado vr6 Yr 1995 so generally I've found diagnostics very limited.
Your last two paragraphs have got me thinking as I can't remember seeing any of this wiring but as for the abs module I have 3 of them, my original then one I bought to try and the third came with the new pump I purchased thats on the car now. My thoughts were to put the original pump back on the corrado along with changing out all the abs sensors maybe check the ecu and see what codes come up.
I was advised to change the abs pump due to faults so did to one guaranteed to work but brakes still not working correctly i sent the old pump off to be serviced by Bba-reman and they can't find any faults, here are some fault codes with the new pump on. Any thoughts please.
Get her to Titanic Dubs.
fleety reacted to a post in a topic: Turbo time
Dogma reacted to a post in a topic: Vw corrado vr6 steering wheel
VR6 Supercharged reacted to a post in a topic: Vw corrado vr6 steering wheel
So after one hour three minutes on hold I finally got speaking to a real live person on PayPal and they agreed that my claim for the steering wheel was valid and I received the refund [emoji857]
