paul.s.evans.127
About paul.s.evans.127
  1. I have an intermittent tap tap from the glovebox area! Any ideas?
  2. Blown fuse 14 by installing a bulb in the passenger side fog light space which I have been told should be left empty All good now
  3. Balls! Plugged my car in to see if there were any new fault codes, cleared some but now my central locking and electro windows don't work!!
  4. V6 4motion rear shocks wanted, cash waiting Also poly bushes
  5. 3 out of 4 were seized, this front one had 1 of the spring clips outside the piston, newish pads too! Pad seats had to have rust filed off so pads moved freely All calipers now free, new disks and pads installed and copper slip The car now brakes as it should! Fluid change tomorrow
  6. New disks and pads all round New flexible prop coupling New aux belt Reconditioned rear caliper All ordered, going to be a busy few days
  7. Front disks are gone and one rear caliper handbrake seized
  8. Front disks only 20% effective and rear n/s caliper handbrake seized!
  9. Turns out there is no signal whatsoever from the sensor!
  10. Was told the ribbon cable may be snapped as the wheel was 20degree off ctr and on full lock may have overstretched it?
  11. Thanks for that, I reset the codes and they all came back, got my eye on an angle sensor on eBay
