steveFC
  1. I am thinking there maybe some adjustment needed on the regulator. I just had a new regulator and that was not due to water getting in. I think the new regulator has maybe been fitted but not adjusted correctly. The seal is literally in as new condition. Steve
  2. Yes, I think any 5 door mk3 front seals will fit, but I have been looking for them and can't see any right now. Will keep an eye open.. not sure the cling film route will last very long tbh. Steve
  3. Yes.. the rain has been setting mine off too in the past so I prob need a seal for a long term solution. Oddly, rear ones are available still and there are some on VW heritage. I can't find front (mine is a 5 door) anywhere. Not the sort of thing i would buy used tbh. Steve
  4. Yep, I had another look at it earlier and it was all wet in there again, I got it washed on the way home Friday. I have left it disconnected for now. You're right about the window seal, I noticed it's not flush with the window on that window only. I guess it will be a nightmare finding another seal? Cheers Steve
  5. Hi all, I am having issues with water getting into my fron N/S window motor or connection. I stripped the door card the other day and disconnected the window as it was opening randomly on its own. I noticed the connector was wet with brown gunge. After cleaning this up and drying it out, the window returned to normal function until i washed the car, it started all over again. I can't understand how water is actually getting intot eh connection to the motor? If anyone has any idea, I waould be very grateful. Cheers - steve
  6. i would say this is almost certainly heater matrix having just done mine (well,, at a garage). i had the exact same symptoms, steamy windows that would not clear, coolant smell and losing a bit of coolant every week. i too was still getting heat ok, and the running temp stayed normal. My heater matrix was really bad when it came out. i would suggest you do it sooner than later as they can blow, then u get the added bonus of coolant all over the carpets.
  7. Thanks Pete, saw this,, cannot face it,, way too scary! haha its no biggy,, will give it to a garage,, was just on the off chance someone nearish fancied some extra work..
  8. Hi,, think Manchester prob a bit too much of an ask,, and i really want someone who has done this job pref a few times (although i am sure u are more than capable),, as its a real pig and this will definitely save time,, but thx anyhow..! Steve
  9. Hi all, I am looking for someone to replace my heater matrix on a 97 Highline,, Not sure if this the done thing on here to post for jobs, but if anyone is willing & very able (i.e done a few b4) , please do get in touch before i go down the garage route. Cheers steve
