GrantVr6
About GrantVr6
  • Birthday 11/28/1975
  1. Had it checked on the dyno and fueling and everything looks fine its only the back cylinders that melts. I had the injectors cleaned and tested. The fuel pumps checked and fuel pressure is fine.
  2. Running stand alone management system with custom map. Forged pistons and compression ration 8.5:1
  3. Hi, I am Grant from South Africa Background: Vr6 turbo charged 2.9 running on 100% ethanol, boosting 2 bar and car makes 407kw and 780 Nm. Problem: Car was fine for 2 years on 1.5 bar and ethanol but now I keep on melting number 3 and 5 piston on higher then 1.6 bar boost. What can I do to still make the power without melting the pistons.
