Zeezee
Everything posted by Zeezee
  1. Zeezee
    Zeezee
  2. Finally got it off as best as I could lifted it up to get to injectors swapped them no can seem to set the manifold back.in place Can't get the alternator side to sit as well as the whole thing under the fuel rail and inline with the manifold holes Hi Timothy hope your well buddy the Bolt that broke is from the bottom right right of manifold when facing the car it's basically this round thing held onto the Mani next to the fuel rail with one small line running to it
  3. gave it a go today removed throttle bodybody connector air hose vacuum lines at rear of intake run in to my first problem can't get two lines off the last one of the the three and the first with the metal bracket I left them till I get help and started removing the bolts on the front second problem Bolt was rusted and head broke off one don't know how to take off any advise again appreciated third problem can't seem to fit a wrench into hex Bolt at rear of manifold bracket next to vacuum lines Is there any way I can get to hidden bolts holding manifold wi
  4. Thanks Tony I guess all that's left is just give it a go take plenty of pics and report back with progress sticking points thanks so much guys love these forums
  5. Thanks bud this is what I'm really worried about I've got the will tools and hopefully skill to open but unfortunately I need an in depth how DIY detailing every hose component Bolt nut to remove and in which order that is something I really need prefferebly with pics as I have a known faulty injector 2 and been told the intake Manny must be removed I have a fuel rail with 6 recon injectors ready to go but can't find that DIY for a 2.8 24v which I desparetly need I have elsawin but don't know where to look and which sections
  6. Thankyou soo much I really appreciate the help bud
  7. Hi I really need someone's kind help I'm trying to replace all 6 injectors on my 24v vr6 I understand to get to them I need to remove the upper intake manifold But for the life of me I can find a 24v DIY to remove intake manifold and fuel rail Can someone please help me with a complete DIY with what else I should replace IE gaskets bushes bolts along the way as well as what intake fuel components I need to remove to get the injectors and rail out I can only find a 12v version I'm getting desperate and to ma
  8. Hi my v6 intermittently from cold starts revs up and then immediately dies, it also does this while car is warm if I stop and restart the issue is very trmptental and intermittent but getting more frequent at cold start the car sounds like a deisel with noise from the drive belt and a chugging coming from engine till it warms up and is then quitier ive also noticed again intermitently mostly in rainy weather when I start the car and whilst driving there is white steamy smoke for the first hour or so, if I park up and retur. To the car and restart it a while later it still
  9. Hi ive got a 2002 VW golf v6 4mo and my fans have both gone 1 I was wandering if the mod will still work if the fans have already gone 2 what brand of fan can people recommend as I don't want to go with the oem ones and face the same resistor problem 3 how hard and does anyone have a guide to remove and replace fans as ice been searching but can't find one 4 my as a result overheats and I have to blast heating is there any tests I should carry out on engine to make sure nothing's damaged 5 I still get some white steamy smoke even t
