Keatonfuller94
About Keatonfuller94
- Birthday 07/03/1994
Gender
Kent
Interests
Vr6
Keatonfuller94 reacted to a post in a topic: Idle problem
also check your air flow mass sensor as well your car shake could also be a warn out engine mount
sorry about my post earlier I fought it was for mine I put up a while ago lol but I have had idle issues with my vr6 since I had it but finally got to the bottom of it, it was loads of little things more than one big thing, but clean your tb make sure there's no gunk from the crack case breather going back in to the tb, check all your earth's in case but usually it would cause bigger issues than 50 revs hope it helps
Hi, I having issues with my mk3 golf vr6, when I start the car up in the mornings, or some times throughout the day it will reset all my clocks and struggle to start, it always start but seems to struggle but also it has and idle issue where the revs will sit at 1000rpm instead of 750-800 rpm, it's had all service parts, all earth's checked and replaced where needed new battery, new alternator, new starter motor, coolant temp sensor any one have any ideas? thanks Keaton
Photoshoot - Calling all VR6's / R32's / R's Owners
Keatonfuller94 replied to VR6Pete's topic in General Chat
It's a shame I don't live closer Sent from my F8331 using The VR6 Owners Club mobile app -
Lovely cheers for the advice much appreciated, my vr6 is a/c delete, and it's had a brand new alternator and battery in the last month I do have to admit I've noticed this a lot more since I put hids on the motor, could a bigger battery help this situation? And I will check my earth from the battery to chassis, I know that the engine to chassis has been replaced Many thanks Keaton
Figured out my funny idle, i believe something isn't man enough on my motor i.e. Battery, it's when I have my hids climate control and stereo on its causes my car to rev at 850-950 and when I turn off the climate control or hids it makes the car tick over at 750 again and will always stay there so is it my battery isn't man enough for the car?? It's a Bosch battery and it's got 540cca?
Where can I locate my fpr?
Still running stock cams but will be hopefully putting in 268 cams soon as I've got to get the lifters done as they knock on col start for 5 mins or so, the car it self runs smooth as, through out all driving it's literally just my idle giving me problems :/ I'll have to get it checked out with vacuum leaks and I bought a new mag from Euros the other day put it on and still no different so I sent it back and got my money back lol
Hi, I have a early 1998 mk3 golf vr6 2.8 which I've owned for a year nearly. Ever since I've owned the car it's had a mind of its own wile idling, sometimes it'll sit at normal idle of 750rpm and other times it's vary from 1000-850 rpm the idle doesn't fluctuate up or down it will stay consistent at the idle it sits at so I believe that takes possibility of it being the coil pack :/ Since owning the car it has had: New 8mm leads Iridium plugs Timing chains have been replaced Aux tensioner Aux belt Alternator Battery Starter motor K&n air induction (57i) New engine earth has been r
Air bag light and abs light after changing the steering wheel
Keatonfuller94 replied to Keatonfuller94's topic in Interior
Cheers fella -
Keatonfuller94 reacted to a post in a topic: Rattle noise from lower right rear of engine bay
Bealieboy reacted to a post in a topic: Rattle noise from lower right rear of engine bay
I thought the timing chains were on the left hand side by the air filter box? Or you on about a different chains? Cause where this noise is coming from is as your facing the front of the car it's at the back right of the engine bay and the air filter box is at the front left, but if you are on about different chains could you help me with what there for and names please so I can get new ones and sort this noise out as I just want it all how it should be lol
