cicciovr6
About cicciovr6
  1. Ho guys Is there someone with a megasquirted vr6?
  2. Hi..for a gti mk2 with 15" wheels what is the best brake upgrade? And for 16" wheels?
  3. Hi...in my golf mk2 gti 8v '91 i have mfa...does will its work with vr6 ecu? For speedometer what cable i need?
  4. Does anyone have got vr6 obd1(with coilpack) Wiring harness diagrams? And also golf 3 vr6 obd2 Wiring harness diagrams
  5. Thanks pete..so i will search a obd1 engine loom
  6. Hi... i have a obd2 engine loom..my engine is a vr6 aaa obd1 with coilpack and i have this ecu 201 906 258F Is it possible to fit obd2 engine loom in my engine with this ecu??
  7. Thanks a lot for those fantastic info!!!! So the limit is gearbox and clutch.. So the safe mode is to run 350hp I ask you some other info: Which head spacer?what compression ratio?? Which head gasket? Is ok gt3882r for 350hp or is it too much bigger? Or gt3076 is the best way to get 350hp?
  8. For around 350hp which turbo is the best?
  9. I'm thinking to driving safety whit 10psi, but in race mode whit 18psi.. So for compression ratio what is the best choise? 9:1 or 8.5:1?
  10. So for a stock internals the boost limit is around 18psi with 9:1 compression ratio? Or 8,5:1 is better than 9:1 whit this boost?
  11. I'm agree with you. But i think there is a safe limit for max boost for example With a ARP hardware what is the max bost for a vr6t?
  12. I ask this to know how much boost stock rods/pistons can handle in safety mode... So my question is: what is the max boost with stock hardware? ( but with a head spacer)
