Gazbvr6
Days Won
6
Everything posted by Gazbvr6
I wouldn't of thought so with bigger maf and injectors on standard map/ecu. I would send the ecu to the tuners to get a base map on it, then you can drive it there for final adjustments on dyno. [emoji106]
I have a 1.8t oem bosch one fitted to mine. I fitted at the same time as the supercharger, so I don't know what runs like without one!
No probs mate[emoji108]
Hi, i'm using piper 264's with my supercharged set up at 6psi and it's been great for the 3 years I've had it supercharged. Although i fitted the cams before the charger so I don't know what gains you'll get going from the standard cams to schimmels. I have heard that the 263's work well with forced induction though mate[emoji106]
Yes vag one preset. Thats why i went for it, plus no piston to get shitted up. 22mm rings a bell but it could be 25 so i may be wrong. I'll try and have look later mate
I used a genuine vw one(bosch) from the 1.8t engine or buy a forge one if you want bling lol
See how you get on. I fitted mine when i fitted the charger so I don't know what it's like without. It stops issues on full bore gear changes as the air/boost has nowhere to go when the throttle plate closes. I'm pretty sure all boosted cars have them
It recircs air back through charger when throttle is closed mate
That looks fantastic! Fair play to you sir[emoji106] Have you not bothered with a recirc valve?
We had a 'guess gaz's horsepower game' at work before it went for mapping!! Lol You will need to run it hard after, as they dont make 6psi till about 6000-6500rpm!!
Good stuff!! I'm interested to see what power it makes[emoji41][emoji41]
Well done mate. Seems you have cracked it [emoji106]
Wow! Lol
Yes i have mate I had mine remapped at stealth
I'm assuming u haven't got your original chip?
Just as tight fitting as my Corrado!! Lol
Mines a Corrado so i also have 4bar pump and reg as standard. Mine runs fine on standard injectors and pump.
Mines a 4bar pump and reg and when at stealth the fuel pressure maxed out 3.5bar. I had changed both the year before so 3.5 sounds about right. Try fitting a 3bar reg from a later engine?
They're in the states aren't they? Is it set up for uk fuel? I doubt it would make much difference to the idle but you never know. Also have you checked the blue temp sensor?
Vince is brilliant mate, it would be well worth the trip. If you have the bigger injectors already why not get a smaller pulley and up the boost? You may aswell[emoji41]
Oh. Just put the standard chip and injectors back in and don't rev it over 4k till you have it mapped [emoji106][emoji106]
Did you plan on having it dyno'd? So at least you can see how it's running mixture wise?? You need it setting up properly really mate.
Is the chip for standard injectors or the uprated ones?
It could be. Don't forget these chargers aren't making boost at idle and if you were running 8-9psi you would need those injectors anyway. It's either the chip or you have an issue elsewhere. Is the maf far enough away from the inlet of the charger?
Hi, mine runs on standard injectors @ 6psi and was mapped by stealth. Anything over that you will need bigger injectors. Hope this helps?
