red_rocket
Days Won
2
red_rocket last won the day on May 20 2021
red_rocket had the most liked content!
About red_rocket
- Birthday 05/19/1963
Gender
Great Dunmow
Interests
Cars, dancing (Ballroom & Latin, plus Argentine tango), gym.
Hi, Are these still available? Cheers Pete
User "bennyk" posted some pictures of the floor repair he did on here around 3rd December 2013. For such a large section you may be better off with repair panel rather than a patch.
Ouch - that's a big hole! The recent restoration quote for my Golf was £400+ ish per day for (cutting out and patching) metalwork. With a sill, or rear wheel arch typical taking a day each. That does not include painting and refinishing.
Hi, I can only answer for my experience of the Mk3 Vr6. I would always now go for Bilstein B4 (or above). I swapped out my yellow Koni's as they were just too stiff for everyday driving on pot holed roads. Cheers Pete
Hi, What is the registration number of the car please, so I can look it up. You can pm me, if you don't want to post it on the forum. Thanks Pete
- 7 replies
- original unmodified example
- digital climatronic
- (and 2 more)
A fluid change is unlikely to fix a missing gear. Assuming its a 01M transmission this is how it works. You move the selector lever which rotates an actuator rod in the gearbox. For reverse and park the rod does mechanical interlock type stuff. For the forward gears, cam faces machined on the rod act on the multifunction switch (MFS) which is a big white thing on the rear side of the gearbox facing the firewall. This generates a 2 or 3 bit code on individual wires which are sent to the gearbox computer. This is located under the rear seat on a Golf but could b
[SOLD] H&R springs for Mk3 Golf VR6 + others
red_rocket replied to red_rocket's topic in Brakes and Suspension
No sorry went within days on here with buyer paying postage. I put SOLD in the title as per the instructions on the classified section. -
yaz79 reacted to a post in a topic: Suspension changing from coil overs to H&r cup kit
SOLD - Golf Mk3 VR6 BBS alloy wheels + tyres
red_rocket replied to red_rocket's topic in Wheels/Tyres
Hi Andrew, Each wheel & tyre weighs about 15.5kg, so you need to check the courier cost. If you want to proceed then I will PM you my address and paypal details. Cheers Pete -
It's possible, but a few questions first; Where are you based? Would the courier take bare wheels (i.e. unwrapped) with just an address label? Which two do you want? Cheers Pete -
Now sold Set of tatty original BBS alloy wheels for Golf Mk3 VR6 1997 - P Reg Sound, with minimal damage, but need a refurb. Balance up OK and only leaked air due to corrosion when the car was in storage for the last 2 years. Toyo T1R 205/50/15 89V tyres included - which are about 4 years and 20K miles old. Also advertised on ebay. Buyer must collect from CM6 1BY (near Stansted airport). Best offer over £40 secures from a VR6OC member. Would consider selling individually (£15 each), if anyone wants proper
Good used condition, some surface rust, but otherwise very good. These are very firm and lower the car by about 40mm front and rear. Available as went back to "standard" for insurance purposes. Also advertised on ebay, but £20 cash to a VR6OC member. Buyer must collect from CM6 1BY (near Stansted airport). Please note that the front springs are designed to fit the 110mm top hat - which is included. Some later cars (like mine) have the 90mm top hat. Cheers Pete
Put it back to standard by changing the airbox and the springs, so I could take out the Hastings policy. It's a standard policy so might have a struggle with the valuation of the VR6 in the event of a fault claim. I will defo go back to the classic policy in 2 years time, when the "car loan" finishes. These really are good value from the specialists and are not bothered about normal mods. Cheers Pete
Hi, I made a similar enquiry recently, actually for exactly the same vehicle type. I was told that you can't get classic insurance for a driver under the age of 25. I was trying to put my son on my classic policy, so he could drive the car while his was being "borrowed" by my daughter when she was back from university. The joys of parenthood! I did however get some online pricings for normal policies for my son, who is 21 with 3 years NCD on the same vehicle. Hastings £500 for a standard car. Flux £1300 for declared mods to suspension and air filte
