milos24v
  1. This is the link of the same part I found on the internet. It says that it fits 2.8-3.2 engine... But it looks like 2.8 water pump... http://xn----7sbanqi1crj1c0e.xn--p1ai
  2. Hello, I searched everywhere, and I can't find an answer on this. I purchased brand new water pump KWP 10617, and it says that it fits oem part no 021121004A 2.8-3.2 golf, etc. But the thing is that that part number is for mk3 12v water pump and as I know 24v/r32 is 021121011. The question is, can I fit mk3 12v water pump on 24v vr6? Cause I read that 24v fits 12v with enlarging holes for 2mm. Thanks a lot...
  3. I'm not sure, it's there for a reason. You should consult someone who tried this, if you don't wanna burn it.
  4. The ECU usually doesn't allow simple recoding, in most cases it's nessesary to remap it with manual ECU map. That is just guessing, we'll find out when I take a car to his garage in two weeks... I'll get back with results...
  5. http://nefariousmotorsports.com/forum/index.php?action=printpage;topic=1843.0 I can't give you more info untill I speak with a men who is going to work on mu wiring. So as soon as I find out something, I'm going to write it here. Cheers.
  6. I just read that it's possible to get a reflash to your auto ECU to works on manual tranny.
  7. Why you just cannot switch to a manual gearbox, and just remove wiring and ecu for a gearbox? I'm asking it because I have ecu and wiring from automatic and swapped it in mk2 golf with manual tranny.
  8. Ok, I understand that, but I want to make it as simple as it can.Can my engine run on it's ecu(with imo defeat etc.) and wiring conected to my ce2, or I need to have all that s**t like ccm, cluster etc?
  9. Hi to all, I'm new on this forum so I will post my project as soon as I can. I searched almost everywhere but I can't find an answer to my question. I have mk2 golf converted to a vr6 from mk3 a few years ago. The engine is now sold, and i swapped it with 2002 seat alhambra 24v vr6 engine. Mechanicaly it was piece of cake, but from the electrical side I new it's going to be a nightmare. Well, the thing is that i have everything from a donor, but my electrician said that I need a BCM. Without it my wiring is useless. I never heard that mk4s, seats and audies have this module. I can't find any u
