Days Won
8
blackwookie last won the day on September 18 2017
blackwookie had the most liked content!
About blackwookie
- Birthday 01/18/1991
Gender
Lancaster PA
Interests
Cars. Music. Bikes. Friends. Beer. 420
2,575 profile views
Anyone know what this brown wire is too? Its in the top left of the pic
Turns out my intermediate sprocket bolt backed out so my upper chain isnt being spun. Trans is coming off and its getting retimed and and hoping for the best here. Gonna locktite thr damn bolt a little this time lol
vr6turbo reacted to a post in a topic: Valve springs
At least its figured out haha
blackwookie reacted to a post in a topic: Mk4 vr6
Swap ur fuel pump. I was having issues with mine not priming. Id smack it and it would prime and fire right up. Swapped the pump for a used one i got for cheap and no isses since
Mk3 golf VR6 slight misfire at low rpm once warm.
blackwookie replied to Olly_Snow's topic in Engine Maintenance and Problems
Im having the same issue...keep getting a lean code p1156. Everyone keeps saying i have an air leak somewhere but i can not find it for the life of me. Been looking for weeks. -
blackwookie reacted to a post in a topic: Mk3 golf VR6 slight misfire at low rpm once warm.
Believe i found an exhaust leak. My gaskets are shot hopefully replacing them gets rid of my p1156 code. https://youtu.be/kUOOEEFnnyU
Thats going to be my next step. Idk what else to do to be honest. Runs smooth as hell im thinking its leaning on idle or very light throttle
I went with autotech valve springs to compliment my techtonics 276 cams. I took it to redline a fee times since and it loves it! I keep getting a p1136 lean code and cant figure out why. Only thing i havnt replaced was my 02 sensor cause it has to be working still. The car runs great i dont know what to do now. Swapped out a 4bar fpr. Changed the coolant temp sensor also. Tried to get a tune and aptuning said its the same file i have already they dont change the file for cams cause my maf and 02 should regulate my air fuel ratios
Coolant temp sensor and oil pressure sensor went in the same week wtf mk4 problems!
Its a 2.8 12v from a 2001 gti engine code afp.
Flylow reacted to a post in a topic: Valve springs
Found an engine 20 min from my house for $150. Got it cleaned painted parts swapped, back in the car. Tune in a few days. It has a brand new 2.5 inch cat back stainless. Whats the update on your car@baker378
motor is in and shes alive boys! Saturday im driving over to aptuning and shes gonna get a flash for the cams. Gonna be awesome cant wait
Bump
blocks cleaned up and painted. And also back in the car. I ordered a fel pro head gasket and a set of fel pro head bolts and the bolts were wrong. I assume i by luck of draw got a mess up, but its just my luck i end up with the bad bolts. Heres a pic of the weird bolt next to one of my old, correct spec, bolt. And a close up of the head of the wrong bolt. Its a total different style
