Kompiesto
About Kompiesto
  1. Hi, I worked on my R30T firstly with my friend RBPE and now, i know more about ME7 and modify my setup by yourself using assambler coding. I created solution to modify internals of ecu with some map changes, as RBPE shows, but all dont work as i want. Problem is with sampling of WBO measurments by MCU. ADC channels are multiplexed with some delay and WBO measurments can move after few minutes of idling. Only good solution is modify MCU code to use BANK 1 corrections of fuel to both banks. I done this but is hard to do. You can run open loop, its simple. Disconnect WBO lambda sensors. F
