ShaunZ
Everything posted by ShaunZ
  1. Looking to install a reverse camera on the MK3 Golf VR6 but don't have any idea which side or colour wires to splice into on the rear light loom for trigger and power. Anyone know? Cheers.
  2. Hi, Anyone got opinions on above? Currently have ramair filter but seems to be running rich with this so thinking about going back to standard airbox with panel filter. Will there be any performance difference or is it just a sound difference. Cheers Shaun
  3. Anyone know if the shallow Vento splitter is a direct fit on a 1996 VR6? Cheers
  4. The Highline has VR6 plastic sill covers.
  5. Hi Can anyone tell me if the front grill "VR6" badge is any different between a Highline and standard VR6. Thanks Shaun
  6. Hi Can anyone tell me if the front grill "VR6" badge is any different between a Highline and standard VR6. Thanks Shaun
  7. Not sure I'm confident enough to have a go so may take to a garage to fit.
  8. Can only find the method where it describes doing from underneath. Assuming you can do refurb from inside the car as you stated but how easy is it for a novice and how long should it take? Thanks
  9. Ok. Thanks. Where did you get the new bush set from?
  10. Anyone know what can be done to resolve pls. In all gears there seems to be a lot of play when in gear. Would this be a case of replacing all selector bushes? If so us there a kit that can be purchased? Cheers Shaun
  11. Only had the vr for a few weeks and am finding bits and pieces as I go. The airbag and abs light indicator was disconnected so after reconnecting I niw have the two lights illuminated. The cae came with a momo steering wheel (no airbag) which I've now replaced with a mk3.5 cabby wheel with airbag. Any ideas how I can get these lights to go off? Also noticed a few plugs that aren't actually connected near front wishbone area. Maybe something to do witg abs? Or would it be best to get an auto electrician out to give the car a once over? Thanks in advance.
  12. Ok cheers. Will check SWG then make a decision. You did mean "can't fault them" rather than "can" didn't you?
  13. Anyone got any views or experience on the quad lights available on ebay. They look pretty good and for £120-150 they seem good value. Rather save my money and wait for a set of hellas or morrettes to come up second hand if not. Thanks in advance. Shaun
