LouieP
Everything posted by LouieP
  1. Sorted the issue out and thought I would update for future readers with an area to check with a similar issue. My main ecu harness had gotten snagged in the coilpack screw and broke two wires, broken wires replaced, soldered and sorted.
  2. Thanks for responding I have not had a good check over as yet. The weather has been quite pathetic here in New Zealand but will have a check on Saturday or Sunday. The plan is check the HT Leads and Coilpack first and give it a shot then move over to the ICV. I scanned the car with obdeleven (obd2) and luckily no codes were stores, I was expecting to see cam sensor and/or crank. Will definitely update this to help the the future readers.
  3. Hey guys, I replaced my cooling system hoses today with some forge motorsport ones. I unforunately did have to remove my coil pack to and leads etc to remove some of the nasty vw clamps however upon starting her up again she was very rough. Any ideas what would cause this? I was very much losing day light so I packed up and said i would have a look tomorrow. Is there anything is should check. Going to recheck my leads and coilpack tomorrow but anything else that I would have over looked?
  4. Hi guys, As above, I am wanting to find out how many oxygen sensors does a OBD2 MK3 VR6, I've searched the web but no definitive answer. The car has a catalytic converter
  5. Thank you phil, your reply is highly appreciated Kind regards
  6. Hi All, I am new to the VR6 world and am trying to sort my project VR6 out. The car seems to be a little hesitant down lown in the rpm and is a little jittery on the pedal. I scanned it with VCDS free version and it continuously throws the codes below. Does this sound similar to anyone of you who have had a similar problem? 00525 - o2 sensor 03-10 00515 - Cam position sensor 30-00 00513 - Engine speed sensor 03-00 (car was turned off - this will show if the car is off correct?) Any help would be appreciated as these parts cost a lot. I checked wir
