Post your rolling road results here!!
  • Replies 146
Popular Posts
http://youtu.be/sLM4Rey0WPg T04E 57trim P turbine wheel .81 housing Eip turbo manifold Flipside customs intake manifold Autotech 262s Bosch 044 with home made surge tank, stock in tank pump Mustang co
mine made 365.2bhp 302 tq mk3 vr6 rotrex c30 94  yesterday at stealth racing good job
I managed to get at the flywheel 188BHP 197lb ft from my 2.9 corrado, with only a pipercross filter (in the standard air box) and a miltek exhaust system, has done 105miles. very impressed with the t
Posted Images
  • 1 month later...
1996 mk3 Golf
24v BDE VR6
United Motorsport Pro-Maf software
3" turbo back
PTE JB 6766 .96
02M with ERF gearing
@ 18psi/1.2bar
518.8hp corrected at the flywheel @ 6678rpm (limiter at 7200rpm which wasn't hit by tester)
428.9 lb/ft torque @ 5633rpm
  • 3 months later...
  • 1 month later...
Power at flywheel (corrected) 203.6 Bhp
Power at wheels 172.6
Max torque speed 4370 rpm
max engine torque 195lb ft
2.8 VR6 ODB2
clocked 117K on way
MK3 Golf
Modded airbox with piper cross panekl filter
schimmel performance 263's
custom (pipecraft) cat back 2.5 stainless
iffy sensor on RR caused jagged lines on plots
http://i1079.photobucket.com/albums/w508/ssaunders71/statscomp.jpg
http://i1079.photobucket.com/albums/w508/ssaunders71/bhp.jpg
http://i1079.photobucket.com/albums/w508/ssaunders71/torque.jpg
post-87425-0-44462800-1385989469_thumb.jpost-87425-0-76743100-1385989481_thumb.j
new stats after Schrick install
hp Corrected Flywheel - 211.7
hp @ wheels - 173.3
Torque - 205.7@3704
pics are last run compared to Owners club run
not a great deal of top end difference but low down torque is the nuts!
Edited by ssaunders
  • 1 month later...
2000 VW GTI MK IV
2000 12v 2.8L VR6 turbo.
- 8.5:1 compression
- 81mm JE pistons, rings and pins
- forged eurospec connecting rods
-ARP head studs
- cam schimmel 263's
- gt35r turbo
- Schimmel performance intake manifold
- Schimmel performance air/water intercooler kit
- ATP turbo exhaust manifold
- Custom 3" exhaust with high-flow cat and muffler
- tial 44mm wastegate
- Greddy type-s Diverter valve
- wavetrac LSD in the trans
- 4" maf housing
- 630cc injectors
- C2 motorsports tune
- H&R coilovers
- Catch Can
- AEM water/meth injection with tank in the trunk
- clutchmaster fx500 clutch kit
- nuespeed short shift kit
- 02J transmission
352 whp
407 tqpost-93692-0-00006400-1390599218_thumb.j
Edited by Zdive65
  • 3 months later...
1995 OBD 1 2.8 12v VR6
Scorpion Mid section, standard Backbox
K&N Induction (badly pieced together had a massive hole on the pipe which I only noticed the other day)
146,000 on the clock
Max Clutch Power: 176.12
Max Clutch Torque : 181.96
Is this not bad for the mileage etc?
So you would say its worth spending a bit of cash on it if i want it quicker?
Not wasting my time? I was looking to get full exhaust system perhaps swapping the K&n with BMC?
Then looking into cams.
Scared with the mileage though that it'll be a waste of time :/
  • 3 weeks later...
  • 2 months later...
Eip turbo manifold
Autotech 262s
Mustang coil
Forge SuperSize DV
3" DP
3" MBS catless exhaust
UM 42lb program
8.5:1 spacer
ARP head studs
USRT pinion brace
Flipside clutch fork
Clutchnet stage 2
Autotech billet steel FW
Devils Own progressive DVC30
25 pounds of boost
Stock differential
Edited by VEE-DUBBER
  • 4 weeks later...
  • 3 months later...
Mk3 obd2 highline
2.8 24v aue
Modified vr6 downpipe to fit 24v manifolds
Vr6 k and n filter above gearbox
Vr6 cat and scorpion cat back exhaust
12v ecu standard map/chip
There was a fault on vag com for cam position sensor
Was getting some det and running bit rich too on WOT
Done at stealth there is two runs one with the inlet flaps open and closed
So got to wire in my vtec controller to switch them on when I get chane
post-94471-0-14038400-1418549179_thumb.j
post-94471-0-94455800-1418549198_thumb.j
  • 1 month later...
  • 7 years later...
2.9 VR6 OBD1 Corrado
263 Cams
Head was refubed when cams fitted
150k bottom end
Stealth remap
Miltek non res
Its had all sensors replaced with new quality items - Bosch etc
I am really interested to compare this to a Schrick VGI car but been through the thread and could only see @VR6Pete in the beginning which made simliar numbers, but peak torque a little lower at 195 ib/ft came in 400rpm lower and I assume more torque overall in the lower rev ranges but would be good to see it on a graph to compare. I'm just looking at where the next best route might be for the car as have had it a long time.
219.7 hp
211  ib/ft torque
Edited by MJA
